Time Before: 0.02329 seconds
Time After: 0.03282 seconds
Time Taken: 0.00952 seconds
Time Before: 0.03290 seconds
Time After: 0.03336 seconds
Time Before: 0.03360 seconds
Time After: 0.03375 seconds
Time Before: 0.03451 seconds
Time After: 0.03698 seconds
Time Taken: 0.00247 seconds
Time Before: 0.03383 seconds
Time After: 0.04152 seconds
Time Taken: 0.00769 seconds
Time Before: 0.05011 seconds
Time After: 0.05060 seconds
Time Before: 0.05308 seconds
Time After: 0.05436 seconds
Time Before: 0.04941 seconds
Time After: 0.05461 seconds
Time Taken: 0.00520 seconds
Time Before: 0.10335 seconds
Time After: 0.10350 seconds
Time Before: 0.11900 seconds
Time After: 0.12027 seconds
End call of global.php: 0.12268090248108
Time Before: 0.12781 seconds
Time After: 0.12797 seconds
Time Before: 0.13004 seconds
Time After: 0.13149 seconds
SET lastactivity = 1783086554, location = '/forums/private.php?do=newpm&explain=1&u=54632', badlocation = 1
Time Before: 0.15121 seconds
Time After: 0.15147 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.14983105659485 seconds with 9 queries, spending 0.0081641674041748 doing MySQL queries and 0.14166688919067 doing PHP things.
