Time Before: 0.02729 seconds
Time After: 0.03405 seconds
Time Taken: 0.00676 seconds
Time Before: 0.03414 seconds
Time After: 0.03456 seconds
Time Before: 0.03481 seconds
Time After: 0.03493 seconds
Time Before: 0.03600 seconds
Time After: 0.03812 seconds
Time Taken: 0.00212 seconds
Time Before: 0.03500 seconds
Time After: 0.04225 seconds
Time Taken: 0.00725 seconds
Time Before: 0.05483 seconds
Time After: 0.05529 seconds
Time Before: 0.05794 seconds
Time After: 0.05910 seconds
Time Taken: 0.00115 seconds
Time Before: 0.05408 seconds
Time After: 0.05930 seconds
Time Taken: 0.00521 seconds
Time Before: 0.11032 seconds
Time After: 0.11049 seconds
Time Before: 0.13187 seconds
Time After: 0.13315 seconds
Time Before: 0.14560 seconds
Time After: 0.14573 seconds
Time Before: 0.14846 seconds
Time After: 0.14992 seconds
UPDATE session SET lastactivity = 1772845863, location = '/forums/private.php?do=newpm&explain=1&u=54634' WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.16936 seconds
Time After: 0.16978 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
