Time Before: 0.01654 seconds
Time After: 0.02060 seconds
Time Taken: 0.00406 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.02069 seconds
Time After: 0.02114 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.02140 seconds
Time After: 0.02158 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.02229 seconds
Time After: 0.02498 seconds
Time Taken: 0.00269 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.02164 seconds
Time After: 0.02894 seconds
Time Taken: 0.00730 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.03510 seconds
Time After: 0.03550 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.03809 seconds
Time After: 0.03934 seconds
Memory Before: 2,771.523 KB
Memory After: 2,771.383 KB
Time Before: 0.03437 seconds
Time After: 0.03960 seconds
Time Taken: 0.00523 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.414 KB
Time Before: 0.06872 seconds
Time After: 0.06886 seconds
Memory Before: 3,437.547 KB
Memory After: 3,438.063 KB
Time Before: 0.08239 seconds
Time After: 0.08364 seconds
Memory Before: 3,525.344 KB
Memory After: 3,525.938 KB
Time Before: 0.09459 seconds
Time After: 0.09476 seconds
Memory Before: 4,163.203 KB
Memory After: 4,163.633 KB
Time Before: 0.09733 seconds
Time After: 0.09919 seconds
Time Taken: 0.00186 seconds
Memory Before: 4,444.766 KB
Memory After: 4,446.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=54662' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.11722 seconds
Time After: 0.11755 seconds
Memory Before: 4,918.352 KB
Memory After: 4,918.594 KB
