Time Before: 0.01864 seconds
Time After: 0.02755 seconds
Time Taken: 0.00891 seconds
Time Before: 0.02767 seconds
Time After: 0.02808 seconds
Time Before: 0.02833 seconds
Time After: 0.02845 seconds
Time Before: 0.02929 seconds
Time After: 0.03225 seconds
Time Taken: 0.00296 seconds
Time Before: 0.02850 seconds
Time After: 0.03595 seconds
Time Taken: 0.00745 seconds
Time Before: 0.04382 seconds
Time After: 0.04441 seconds
Time Taken: 0.00059 seconds
Time Before: 0.04766 seconds
Time After: 0.04911 seconds
Time Before: 0.04302 seconds
Time After: 0.04929 seconds
Time Taken: 0.00628 seconds
Time Before: 0.09518 seconds
Time After: 0.09649 seconds
Time Taken: 0.00132 seconds
Time Before: 0.11472 seconds
Time After: 0.11596 seconds
End call of global.php: 0.11815190315247
Time Before: 0.12793 seconds
Time After: 0.12819 seconds
Time Before: 0.13084 seconds
Time After: 0.13228 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=54713'
Time Before: 0.15030 seconds
Time After: 0.15058 seconds
Memory Before: 4,911.656 KB
Memory After: 4,911.898 KB
Page generated in 0.1491539478302 seconds with 9 queries, spending 0.010048627853394 doing MySQL queries and 0.13910531997681 doing PHP things.
