Time Before: 0.00216 seconds
Time After: 0.00299 seconds
Time Taken: 0.00082 seconds
Time Before: 0.00308 seconds
Time After: 0.00354 seconds
Time Before: 0.00382 seconds
Time After: 0.00399 seconds
Time Before: 0.00483 seconds
Time After: 0.00807 seconds
Time Taken: 0.00324 seconds
Time Before: 0.00406 seconds
Time After: 0.01309 seconds
Time Taken: 0.00902 seconds
Time Before: 0.01627 seconds
Time After: 0.01651 seconds
Time Before: 0.01953 seconds
Time After: 0.02095 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01551 seconds
Time After: 0.02125 seconds
Time Taken: 0.00574 seconds
Memory After: 2,261.836 KB
Time Before: 0.03538 seconds
Time After: 0.03555 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.06073 seconds
Time After: 0.06198 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.064141035079956
Time Before: 0.06847 seconds
Time After: 0.06871 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.07152 seconds
Time After: 0.07297 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789039042, location = '/forums/private.php?do=newpm&explain=1&u=54748', badlocation = 1
Time Before: 0.09377 seconds
Time After: 0.09399 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.092473030090332 seconds with 9 queries, spending 0.0088448524475098 doing MySQL queries and 0.083628177642822 doing PHP things.
