Time Before: 0.00224 seconds
Time After: 0.00288 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00305 seconds
Time After: 0.00347 seconds
Time Before: 0.00371 seconds
Time After: 0.00384 seconds
Time Before: 0.00464 seconds
Time After: 0.00743 seconds
Time Taken: 0.00279 seconds
Time Before: 0.00392 seconds
Time After: 0.01102 seconds
Time Taken: 0.00710 seconds
Time Before: 0.01298 seconds
Time After: 0.01339 seconds
Time Before: 0.01617 seconds
Time After: 0.01736 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01232 seconds
Time After: 0.01761 seconds
Time Taken: 0.00530 seconds
Memory After: 2,261.719 KB
Time Before: 0.02523 seconds
Time After: 0.02538 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.02812 seconds
Time After: 0.02935 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.032159090042114
Time Before: 0.03359 seconds
Time After: 0.03373 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.03636 seconds
Time After: 0.03778 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=54944', badlocation = 1
Time Before: 0.05120 seconds
Time After: 0.05148 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.050286054611206 seconds with 9 queries, spending 0.0081710815429688 doing MySQL queries and 0.042114973068237 doing PHP things.
