Time Before: 0.00153 seconds
Time After: 0.00210 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00217 seconds
Time After: 0.00258 seconds
Time Before: 0.00275 seconds
Time After: 0.00287 seconds
Time Before: 0.00355 seconds
Time After: 0.00608 seconds
Time Taken: 0.00253 seconds
Time Before: 0.00292 seconds
Time After: 0.00945 seconds
Time Taken: 0.00654 seconds
Time Before: 0.01132 seconds
Time After: 0.01173 seconds
Time Before: 0.01426 seconds
Time After: 0.01548 seconds
Time Before: 0.01069 seconds
Time After: 0.01564 seconds
Time Taken: 0.00495 seconds
Time Before: 0.02130 seconds
Time After: 0.02158 seconds
Time Before: 0.02358 seconds
Time After: 0.02485 seconds
Time Before: 0.02761 seconds
Time After: 0.02774 seconds
Time Before: 0.02969 seconds
Time After: 0.03112 seconds
UPDATE session SET lastactivity = 1789051395, location = '/forums/private.php?do=newpm&explain=1&u=54967', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04395 seconds
Time After: 0.04423 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
