Time Before: 0.02193 seconds
Time After: 0.02829 seconds
Time Taken: 0.00636 seconds
Time Before: 0.02837 seconds
Time After: 0.02875 seconds
Time Before: 0.02896 seconds
Time After: 0.02906 seconds
Time Before: 0.02981 seconds
Time After: 0.03253 seconds
Time Taken: 0.00272 seconds
Time Before: 0.02912 seconds
Time After: 0.03616 seconds
Time Taken: 0.00705 seconds
Time Before: 0.04388 seconds
Time After: 0.04428 seconds
Time Before: 0.04678 seconds
Time After: 0.04794 seconds
Time Taken: 0.00117 seconds
Time Before: 0.04322 seconds
Time After: 0.04815 seconds
Time Taken: 0.00492 seconds
Time Before: 0.07976 seconds
Time After: 0.07993 seconds
Time Before: 0.10208 seconds
Time After: 0.10364 seconds
Time Taken: 0.00156 seconds
End call of global.php: 0.10616207122803
Time Before: 0.11088 seconds
Time After: 0.11107 seconds
Time Before: 0.11412 seconds
Time After: 0.11562 seconds
SET lastactivity = 1782960476, location = '/forums/private.php?do=newpm&explain=1&u=54990', badlocation = 1
Time Before: 0.13190 seconds
Time After: 0.13228 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.13075494766235 seconds with 9 queries, spending 0.0085620880126953 doing MySQL queries and 0.12219285964966 doing PHP things.
