Time Before: 0.00523 seconds
Time After: 0.00749 seconds
Time Taken: 0.00226 seconds
Time Before: 0.00759 seconds
Time After: 0.00806 seconds
Time Before: 0.00830 seconds
Time After: 0.00846 seconds
Time Before: 0.00918 seconds
Time After: 0.01192 seconds
Time Taken: 0.00273 seconds
Time Before: 0.00852 seconds
Time After: 0.01531 seconds
Time Taken: 0.00678 seconds
Time Before: 0.01807 seconds
Time After: 0.01848 seconds
Time Before: 0.02089 seconds
Time After: 0.02216 seconds
Time Before: 0.01744 seconds
Time After: 0.02239 seconds
Time Taken: 0.00496 seconds
Time Before: 0.03390 seconds
Time After: 0.03412 seconds
Time Before: 0.03788 seconds
Time After: 0.03915 seconds
End call of global.php: 0.040776014328003
Time Before: 0.04291 seconds
Time After: 0.04315 seconds
Time Before: 0.04582 seconds
Time After: 0.04739 seconds
Time Taken: 0.00157 seconds
SET lastactivity = 1780612778, location = '/forums/private.php?do=newpm&explain=1&u=55039'
WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.06282 seconds
Time After: 0.06325 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.061890125274658 seconds with 9 queries, spending 0.008779764175415 doing MySQL queries and 0.053110361099243 doing PHP things.
