Time Before: 0.02817 seconds
Time After: 0.03321 seconds
Time Taken: 0.00504 seconds
Time Before: 0.03330 seconds
Time After: 0.03371 seconds
Time Before: 0.03395 seconds
Time After: 0.03408 seconds
Time Before: 0.03498 seconds
Time After: 0.03789 seconds
Time Taken: 0.00290 seconds
Time Before: 0.03415 seconds
Time After: 0.04237 seconds
Time Taken: 0.00822 seconds
Time Before: 0.05452 seconds
Time After: 0.05493 seconds
Time Before: 0.05777 seconds
Time After: 0.05898 seconds
Time Before: 0.05374 seconds
Time After: 0.05926 seconds
Time Taken: 0.00551 seconds
Time Before: 0.11155 seconds
Time After: 0.11172 seconds
Time Before: 0.13071 seconds
Time After: 0.13199 seconds
End call of global.php: 0.13419508934021
Time Before: 0.14458 seconds
Time After: 0.14471 seconds
Time Before: 0.14717 seconds
Time After: 0.14882 seconds
Time Taken: 0.00165 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=5504', badlocation = 1
Time Before: 0.16598 seconds
Time After: 0.16631 seconds
Memory Before: 4,911.086 KB
Memory After: 4,911.313 KB
Page generated in 0.16498899459839 seconds with 9 queries, spending 0.0086343288421631 doing MySQL queries and 0.15635466575623 doing PHP things.
