Time Before: 0.01288 seconds
Time After: 0.01987 seconds
Time Taken: 0.00699 seconds
Time Before: 0.01996 seconds
Time After: 0.02038 seconds
Time Before: 0.02056 seconds
Time After: 0.02068 seconds
Time Before: 0.02130 seconds
Time After: 0.02338 seconds
Time Taken: 0.00208 seconds
Time Before: 0.02074 seconds
Time After: 0.02750 seconds
Time Taken: 0.00676 seconds
Time Before: 0.03567 seconds
Time After: 0.03604 seconds
Time Before: 0.03775 seconds
Time After: 0.03894 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.03482 seconds
Time After: 0.03916 seconds
Time Taken: 0.00434 seconds
Memory After: 2,261.719 KB
Time Before: 0.05817 seconds
Time After: 0.05831 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.07198 seconds
Time After: 0.07321 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.075195074081421
Time Before: 0.07977 seconds
Time After: 0.07989 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.08203 seconds
Time After: 0.08411 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=55074'
Time Before: 0.10081 seconds
Time After: 0.10136 seconds
Time Taken: 0.00055 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.099684000015259 seconds with 9 queries, spending 0.0083119869232178 doing MySQL queries and 0.091372013092041 doing PHP things.
