Time Before: 0.01979 seconds
Time After: 0.02687 seconds
Time Taken: 0.00708 seconds
Time Before: 0.02695 seconds
Time After: 0.02738 seconds
Time Before: 0.02761 seconds
Time After: 0.02773 seconds
Time Before: 0.02852 seconds
Time After: 0.03089 seconds
Time Taken: 0.00237 seconds
Time Before: 0.02780 seconds
Time After: 0.03488 seconds
Time Before: 0.04298 seconds
Time After: 0.04343 seconds
Time Before: 0.04680 seconds
Time After: 0.04801 seconds
Time Before: 0.04226 seconds
Time After: 0.04828 seconds
Time Taken: 0.00601 seconds
Time Before: 0.08719 seconds
Time After: 0.08734 seconds
Time Before: 0.10738 seconds
Time After: 0.10870 seconds
Time Taken: 0.00132 seconds
Time Before: 0.12008 seconds
Time After: 0.12026 seconds
Time Before: 0.12267 seconds
Time After: 0.12421 seconds
Time Taken: 0.00154 seconds
UPDATE session SET lastactivity = 1785305393, location = '/forums/private.php?do=newpm&explain=1&u=55092' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.14190 seconds
Time After: 0.14222 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
