Time Before: 0.01002 seconds
Time After: 0.01509 seconds
Time Taken: 0.00507 seconds
Time Before: 0.01519 seconds
Time After: 0.01564 seconds
Time Before: 0.01586 seconds
Time After: 0.01602 seconds
Time Before: 0.01676 seconds
Time After: 0.01883 seconds
Time Taken: 0.00207 seconds
Time Before: 0.01608 seconds
Time After: 0.02337 seconds
Time Taken: 0.00728 seconds
Time Before: 0.02983 seconds
Time After: 0.03029 seconds
Time Before: 0.03288 seconds
Time After: 0.03412 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02907 seconds
Time After: 0.03439 seconds
Time Taken: 0.00533 seconds
Memory After: 2,261.836 KB
Time Before: 0.05289 seconds
Time After: 0.05306 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.06838 seconds
Time After: 0.06963 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.071781158447266
Time Before: 0.07868 seconds
Time After: 0.07884 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.08134 seconds
Time After: 0.08284 seconds
Time Taken: 0.00150 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789080523, location = '/forums/private.php?do=newpm&explain=1&u=55211'
Time Before: 0.10074 seconds
Time After: 0.10123 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.099691152572632 seconds with 9 queries, spending 0.0079476833343506 doing MySQL queries and 0.091743469238281 doing PHP things.
