Time Before: 0.04171 seconds
Time After: 0.05408 seconds
Time Taken: 0.01238 seconds
Time Before: 0.05418 seconds
Time After: 0.05470 seconds
Time Before: 0.05494 seconds
Time After: 0.05511 seconds
Time Before: 0.05580 seconds
Time After: 0.05782 seconds
Time Taken: 0.00202 seconds
Time Before: 0.05517 seconds
Time After: 0.06230 seconds
Time Taken: 0.00714 seconds
Time Before: 0.07573 seconds
Time After: 0.07607 seconds
Time Before: 0.07748 seconds
Time After: 0.07908 seconds
Time Taken: 0.00160 seconds
Time Before: 0.07498 seconds
Time After: 0.07925 seconds
Time Taken: 0.00427 seconds
Time Before: 0.14036 seconds
Time After: 0.14053 seconds
Time Before: 0.18551 seconds
Time After: 0.18678 seconds
Time Before: 0.21202 seconds
Time After: 0.21219 seconds
Time Before: 0.21546 seconds
Time After: 0.21692 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=55280', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.24050 seconds
Time After: 0.24080 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
