Time Before: 0.01141 seconds
Time After: 0.01441 seconds
Time Taken: 0.00300 seconds
Time Before: 0.01451 seconds
Time After: 0.01491 seconds
Time Before: 0.01513 seconds
Time After: 0.01526 seconds
Time Before: 0.01606 seconds
Time After: 0.01838 seconds
Time Taken: 0.00232 seconds
Time Before: 0.01532 seconds
Time After: 0.02181 seconds
Time Taken: 0.00649 seconds
Time Before: 0.02734 seconds
Time After: 0.02774 seconds
Time Before: 0.03081 seconds
Time After: 0.03200 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.02662 seconds
Time After: 0.03218 seconds
Time Taken: 0.00555 seconds
Memory After: 2,261.719 KB
Time Before: 0.04931 seconds
Time After: 0.04950 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.06013 seconds
Time After: 0.06137 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.063362836837769
Time Before: 0.06770 seconds
Time After: 0.06814 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.07071 seconds
Time After: 0.07219 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=55303', badlocation = 1
Time Before: 0.09284 seconds
Time After: 0.09320 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.091440916061401 seconds with 9 queries, spending 0.0081532001495361 doing MySQL queries and 0.083287715911865 doing PHP things.
