Time Before: 0.02358 seconds
Time After: 0.03150 seconds
Time Taken: 0.00792 seconds
Time Before: 0.03162 seconds
Time After: 0.03217 seconds
Time Taken: 0.00056 seconds
Time Before: 0.03243 seconds
Time After: 0.03267 seconds
Time Before: 0.03356 seconds
Time After: 0.03572 seconds
Time Taken: 0.00217 seconds
Time Before: 0.03274 seconds
Time After: 0.04103 seconds
Time Taken: 0.00829 seconds
Time Before: 0.04811 seconds
Time After: 0.04855 seconds
Time Before: 0.05113 seconds
Time After: 0.05244 seconds
Time Taken: 0.00132 seconds
Time Before: 0.04739 seconds
Time After: 0.05266 seconds
Time Taken: 0.00528 seconds
Time Before: 0.08346 seconds
Time After: 0.08371 seconds
Time Before: 0.64743 seconds
Time After: 0.64941 seconds
Time Taken: 0.00198 seconds
Time Before: 0.66365 seconds
Time After: 0.66392 seconds
Time Before: 0.66664 seconds
Time After: 0.66817 seconds
Time Taken: 0.00153 seconds
UPDATE session SET lastactivity = 1784857901, location = '/forums/private.php?do=newpm&explain=1&u=55318', badlocation = 1 WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.68799 seconds
Time After: 0.68826 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
