Time Before: 0.00164 seconds
Time After: 0.00218 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00228 seconds
Time After: 0.00268 seconds
Time Before: 0.00292 seconds
Time After: 0.00309 seconds
Time Before: 0.00395 seconds
Time After: 0.00690 seconds
Time Taken: 0.00295 seconds
Time Before: 0.00317 seconds
Time After: 0.01163 seconds
Time Taken: 0.00846 seconds
Time Before: 0.01368 seconds
Time After: 0.01408 seconds
Time Before: 0.01560 seconds
Time After: 0.01688 seconds
Time Before: 0.01297 seconds
Time After: 0.01713 seconds
Time Taken: 0.00415 seconds
Time Before: 0.02314 seconds
Time After: 0.02336 seconds
Time Before: 0.02582 seconds
Time After: 0.02713 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.029582023620605
Time Before: 0.03102 seconds
Time After: 0.03124 seconds
Time Before: 0.03342 seconds
Time After: 0.03484 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=55391', badlocation = 1
WHERE sessionhash = 'fb8546df1d172120a5a514bbe0406f9a'
Time Before: 0.04761 seconds
Time After: 0.04787 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.046705961227417 seconds with 9 queries, spending 0.0086238384246826 doing MySQL queries and 0.038082122802734 doing PHP things.
