Time Before: 0.02124 seconds
Time After: 0.02614 seconds
Time Taken: 0.00491 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02623 seconds
Time After: 0.02662 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02694 seconds
Time After: 0.02712 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02796 seconds
Time After: 0.03007 seconds
Time Taken: 0.00210 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02723 seconds
Time After: 0.03474 seconds
Time Taken: 0.00751 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.03896 seconds
Time After: 0.03938 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04205 seconds
Time After: 0.04321 seconds
Time Taken: 0.00116 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.03831 seconds
Time After: 0.04340 seconds
Time Taken: 0.00509 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.07694 seconds
Time After: 0.07711 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.12404 seconds
Time After: 0.12528 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.12817192077637
Time Before: 0.15786 seconds
Time After: 0.15805 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.16324 seconds
Time After: 0.16472 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=55428'
WHERE sessionhash = 'fb8546df1d172120a5a514bbe0406f9a'
Time Before: 0.18692 seconds
Time After: 0.18901 seconds
Memory Before: 5,997.453 KB
Memory After: 5,997.695 KB
Page generated in 0.18597006797791 seconds with 9 queries, spending 0.0094280242919922 doing MySQL queries and 0.17654204368591 doing PHP things.
