Time Before: 0.00146 seconds
Time After: 0.00192 seconds
Time Before: 0.00199 seconds
Time After: 0.00245 seconds
Time Before: 0.00263 seconds
Time After: 0.00273 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00345 seconds
Time After: 0.00636 seconds
Time Taken: 0.00291 seconds
Time Before: 0.00278 seconds
Time After: 0.01119 seconds
Time Taken: 0.00841 seconds
Time Before: 0.01354 seconds
Time After: 0.01397 seconds
Time Before: 0.01697 seconds
Time After: 0.01839 seconds
Time Before: 0.01281 seconds
Time After: 0.01858 seconds
Time Taken: 0.00577 seconds
Time Before: 0.02397 seconds
Time After: 0.02443 seconds
Time Before: 0.02642 seconds
Time After: 0.02765 seconds
End call of global.php: 0.029296159744263
Time Before: 0.03053 seconds
Time After: 0.03066 seconds
Time Before: 0.03260 seconds
Time After: 0.03400 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=55484'
Time Before: 0.04628 seconds
Time After: 0.04666 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.045407056808472 seconds with 9 queries, spending 0.0089213848114014 doing MySQL queries and 0.03648567199707 doing PHP things.
