Time Before: 0.00143 seconds
Time After: 0.00221 seconds
Time Taken: 0.00079 seconds
Time Before: 0.00228 seconds
Time After: 0.00267 seconds
Time Before: 0.00287 seconds
Time After: 0.00307 seconds
Time Before: 0.00372 seconds
Time After: 0.00614 seconds
Time Taken: 0.00242 seconds
Time Before: 0.00311 seconds
Time After: 0.00997 seconds
Time Taken: 0.00686 seconds
Time Before: 0.01195 seconds
Time After: 0.01216 seconds
Time Before: 0.01370 seconds
Time After: 0.01613 seconds
Time Taken: 0.00244 seconds
Time Before: 0.01132 seconds
Time After: 0.01632 seconds
Time Taken: 0.00500 seconds
Time Before: 0.02147 seconds
Time After: 0.02166 seconds
Time Before: 0.02344 seconds
Time After: 0.02472 seconds
End call of global.php: 0.027158975601196
Time Before: 0.02843 seconds
Time After: 0.02857 seconds
Time Before: 0.03105 seconds
Time After: 0.03256 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1772785692, location = '/forums/private.php?do=newpm&explain=1&u=55520', badlocation = 1
WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.04670 seconds
Time After: 0.04702 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.04567289352417 seconds with 9 queries, spending 0.0090808868408203 doing MySQL queries and 0.03659200668335 doing PHP things.
