Time Before: 0.00132 seconds
Time After: 0.00183 seconds
Time Before: 0.00190 seconds
Time After: 0.00234 seconds
Time Before: 0.00256 seconds
Time After: 0.00269 seconds
Time Before: 0.00334 seconds
Time After: 0.00619 seconds
Time Taken: 0.00284 seconds
Time Before: 0.00274 seconds
Time After: 0.01027 seconds
Time Taken: 0.00753 seconds
Time Before: 0.01222 seconds
Time After: 0.01258 seconds
Time Before: 0.01500 seconds
Time After: 0.01659 seconds
Time Taken: 0.00159 seconds
Time Before: 0.01159 seconds
Time After: 0.01682 seconds
Time Taken: 0.00523 seconds
Time Before: 0.02361 seconds
Time After: 0.02378 seconds
Time Before: 0.02650 seconds
Time After: 0.02782 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.030313014984131
Time Before: 0.03169 seconds
Time After: 0.03186 seconds
Time Before: 0.03389 seconds
Time After: 0.03542 seconds
Time Taken: 0.00153 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=55532', badlocation = 1
Time Before: 0.04958 seconds
Time After: 0.04984 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.048609972000122 seconds with 9 queries, spending 0.0088152885437012 doing MySQL queries and 0.039794683456421 doing PHP things.
