Time Before: 0.00952 seconds
Time After: 0.01147 seconds
Time Taken: 0.00195 seconds
Memory Before: 532.906 KB
Memory After: 558.023 KB
Time Before: 0.01159 seconds
Time After: 0.01208 seconds
Memory Before: 557.961 KB
Memory After: 558.969 KB
Time Before: 0.01234 seconds
Time After: 0.01249 seconds
Memory Before: 559.523 KB
Memory After: 560.047 KB
Time Before: 0.01329 seconds
Time After: 0.01592 seconds
Time Taken: 0.00263 seconds
Memory Before: 562.648 KB
Memory After: 563.570 KB
Time Before: 0.01258 seconds
Time After: 0.02038 seconds
Time Taken: 0.00780 seconds
Memory Before: 559.297 KB
Memory After: 1,640.391 KB
Memory Used: 1,081.094 KB
Time Before: 0.02580 seconds
Time After: 0.02620 seconds
Memory Before: 2,135.344 KB
Memory After: 2,135.961 KB
Time Before: 0.02912 seconds
Time After: 0.03038 seconds
Memory Before: 2,147.523 KB
Memory After: 2,147.383 KB
Time Before: 0.02464 seconds
Time After: 0.03067 seconds
Time Taken: 0.00603 seconds
Memory Before: 2,127.523 KB
Memory After: 2,260.734 KB
Memory Used: 133.211 KB
Time Before: 0.04777 seconds
Time After: 0.04791 seconds
Memory Before: 2,814.250 KB
Memory After: 2,814.766 KB
Time Before: 0.06147 seconds
Time After: 0.06276 seconds
Memory Before: 2,902.586 KB
Memory After: 2,903.180 KB
Time Before: 0.07191 seconds
Time After: 0.07206 seconds
Memory Before: 3,539.344 KB
Memory After: 3,539.773 KB
Time Before: 0.07456 seconds
Time After: 0.07603 seconds
Memory Before: 3,821.078 KB
Memory After: 3,822.766 KB
UPDATE session SET lastactivity = 1785386317, location = '/forums/private.php?do=newpm&explain=1&u=55565' WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.09354 seconds
Time After: 0.09386 seconds
Memory Before: 4,299.250 KB
Memory After: 4,299.477 KB
