Time Before: 0.01093 seconds
Time After: 0.01828 seconds
Time Taken: 0.00735 seconds
Time Before: 0.01838 seconds
Time After: 0.01886 seconds
Time Before: 0.01909 seconds
Time After: 0.01922 seconds
Time Before: 0.01994 seconds
Time After: 0.02207 seconds
Time Taken: 0.00212 seconds
Time Before: 0.01930 seconds
Time After: 0.02589 seconds
Time Taken: 0.00659 seconds
Time Before: 0.03319 seconds
Time After: 0.03373 seconds
Time Taken: 0.00053 seconds
Time Before: 0.03538 seconds
Time After: 0.03660 seconds
Time Before: 0.03247 seconds
Time After: 0.03685 seconds
Time Taken: 0.00438 seconds
Time Before: 0.06234 seconds
Time After: 0.06247 seconds
Time Before: 0.07892 seconds
Time After: 0.08018 seconds
End call of global.php: 0.082779884338379
Time Before: 0.08865 seconds
Time After: 0.08879 seconds
Time Before: 0.09134 seconds
Time After: 0.09287 seconds
Time Taken: 0.00153 seconds
SET lastactivity = 1776621586, location = '/forums/private.php?do=newpm&explain=1&u=55604', badlocation = 1
Time Before: 0.11070 seconds
Time After: 0.11102 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.10976791381836 seconds with 9 queries, spending 0.0078771114349365 doing MySQL queries and 0.10189080238342 doing PHP things.
