Time Before: 0.00206 seconds
Time After: 0.00304 seconds
Time Taken: 0.00098 seconds
Time Before: 0.00313 seconds
Time After: 0.00360 seconds
Time Before: 0.00384 seconds
Time After: 0.00402 seconds
Time Before: 0.00495 seconds
Time After: 0.00731 seconds
Time Taken: 0.00236 seconds
Time Before: 0.00409 seconds
Time After: 0.01268 seconds
Time Taken: 0.00859 seconds
Time Before: 0.01530 seconds
Time After: 0.01567 seconds
Time Before: 0.01832 seconds
Time After: 0.01951 seconds
Time Before: 0.01448 seconds
Time After: 0.01977 seconds
Time Taken: 0.00529 seconds
Time Before: 0.02670 seconds
Time After: 0.02687 seconds
Time Before: 0.02926 seconds
Time After: 0.03048 seconds
Time Before: 0.03346 seconds
Time After: 0.03362 seconds
Time Before: 0.03561 seconds
Time After: 0.03707 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=55678' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.04954 seconds
Time After: 0.04979 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
