Time Before: 0.01303 seconds
Time After: 0.01943 seconds
Time Taken: 0.00640 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.01951 seconds
Time After: 0.01996 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02019 seconds
Time After: 0.02033 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02121 seconds
Time After: 0.02341 seconds
Time Taken: 0.00220 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02039 seconds
Time After: 0.02783 seconds
Time Taken: 0.00744 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.03478 seconds
Time After: 0.03523 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.03853 seconds
Time After: 0.03976 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.03389 seconds
Time After: 0.03999 seconds
Time Taken: 0.00610 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.07645 seconds
Time After: 0.07661 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.11416 seconds
Time After: 0.11543 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.11832284927368
Time Before: 0.13874 seconds
Time After: 0.13890 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.14300 seconds
Time After: 0.14443 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=55717'
Time Before: 0.16578 seconds
Time After: 0.16600 seconds
Memory Before: 5,997.453 KB
Memory After: 5,997.695 KB
Page generated in 0.16479897499084 seconds with 9 queries, spending 0.0077080726623535 doing MySQL queries and 0.15709090232849 doing PHP things.
