Time Before: 0.00178 seconds
Time After: 0.00230 seconds
Time Before: 0.00237 seconds
Time After: 0.00278 seconds
Time Before: 0.00300 seconds
Time After: 0.00313 seconds
Time Before: 0.00386 seconds
Time After: 0.00656 seconds
Time Taken: 0.00270 seconds
Time Before: 0.00318 seconds
Time After: 0.01164 seconds
Time Taken: 0.00846 seconds
Time Before: 0.01358 seconds
Time After: 0.01397 seconds
Time Before: 0.01635 seconds
Time After: 0.01759 seconds
Time Before: 0.01296 seconds
Time After: 0.01779 seconds
Time Taken: 0.00483 seconds
Time Before: 0.02355 seconds
Time After: 0.02370 seconds
Time Before: 0.02591 seconds
Time After: 0.02715 seconds
End call of global.php: 0.029046058654785
Time Before: 0.03022 seconds
Time After: 0.03039 seconds
Time Before: 0.03281 seconds
Time After: 0.03428 seconds
SET lastactivity = 1788887292, location = '/forums/private.php?do=newpm&explain=1&u=55777'
Time Before: 0.04674 seconds
Time After: 0.04760 seconds
Time Taken: 0.00086 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.045834064483643 seconds with 9 queries, spending 0.0087707042694092 doing MySQL queries and 0.037063360214233 doing PHP things.
