Time Before: 0.00136 seconds
Time After: 0.00194 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00200 seconds
Time After: 0.00251 seconds
Time Before: 0.00281 seconds
Time After: 0.00296 seconds
Time Before: 0.00406 seconds
Time After: 0.00684 seconds
Time Taken: 0.00278 seconds
Time Before: 0.00304 seconds
Time After: 0.01156 seconds
Time Taken: 0.00853 seconds
Time Before: 0.01322 seconds
Time After: 0.01381 seconds
Time Taken: 0.00059 seconds
Time Before: 0.01569 seconds
Time After: 0.01691 seconds
Time Before: 0.01267 seconds
Time After: 0.01709 seconds
Time Taken: 0.00442 seconds
Time Before: 0.02234 seconds
Time After: 0.02256 seconds
Time Before: 0.02526 seconds
Time After: 0.02648 seconds
End call of global.php: 0.029043912887573
Time Before: 0.03030 seconds
Time After: 0.03045 seconds
Time Before: 0.03324 seconds
Time After: 0.03473 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=55799'
Time Before: 0.05043 seconds
Time After: 0.05072 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.049094915390015 seconds with 9 queries, spending 0.0086212158203125 doing MySQL queries and 0.040473699569702 doing PHP things.
