Time Before: 0.01464 seconds
Time After: 0.01832 seconds
Time Taken: 0.00369 seconds
Time Before: 0.01842 seconds
Time After: 0.01887 seconds
Time Before: 0.01913 seconds
Time After: 0.01936 seconds
Time Before: 0.02019 seconds
Time After: 0.02340 seconds
Time Taken: 0.00321 seconds
Time Before: 0.01943 seconds
Time After: 0.02759 seconds
Time Taken: 0.00816 seconds
Time Before: 0.03259 seconds
Time After: 0.03297 seconds
Time Before: 0.03549 seconds
Time After: 0.03706 seconds
Time Taken: 0.00157 seconds
Time Before: 0.03201 seconds
Time After: 0.03732 seconds
Time Taken: 0.00530 seconds
Time Before: 0.06681 seconds
Time After: 0.06697 seconds
Time Before: 0.08019 seconds
Time After: 0.08147 seconds
Time Before: 0.09072 seconds
Time After: 0.09089 seconds
Time Before: 0.09325 seconds
Time After: 0.09482 seconds
UPDATE session SET lastactivity = 1789109735, location = '/forums/private.php?do=newpm&explain=1&u=55916' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.11541 seconds
Time After: 0.11629 seconds
Time Taken: 0.00087 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
