Time Before: 0.01165 seconds
Time After: 0.01722 seconds
Time Taken: 0.00557 seconds
Time Before: 0.01732 seconds
Time After: 0.01771 seconds
Time Before: 0.01805 seconds
Time After: 0.01817 seconds
Time Before: 0.01896 seconds
Time After: 0.02100 seconds
Time Taken: 0.00204 seconds
Time Before: 0.01824 seconds
Time After: 0.02525 seconds
Time Taken: 0.00701 seconds
Time Before: 0.03179 seconds
Time After: 0.03217 seconds
Time Before: 0.03480 seconds
Time After: 0.03601 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.03105 seconds
Time After: 0.03625 seconds
Time Taken: 0.00520 seconds
Memory After: 2,261.836 KB
Time Before: 0.05548 seconds
Time After: 0.05560 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.54959 seconds
Time After: 0.55159 seconds
Time Taken: 0.00200 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.55385303497314
Time Before: 0.56300 seconds
Time After: 0.56317 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.56634 seconds
Time After: 0.56835 seconds
Time Taken: 0.00201 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789146823, location = '/forums/private.php?do=newpm&explain=1&u=56019', badlocation = 1
Time Before: 0.58683 seconds
Time After: 0.58711 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.58567500114441 seconds with 9 queries, spending 0.0087132453918457 doing MySQL queries and 0.57696175575256 doing PHP things.
