Time Before: 0.02086 seconds
Time After: 0.02683 seconds
Time Taken: 0.00597 seconds
Time Before: 0.02691 seconds
Time After: 0.02735 seconds
Time Before: 0.02761 seconds
Time After: 0.02774 seconds
Time Before: 0.02842 seconds
Time After: 0.03089 seconds
Time Taken: 0.00247 seconds
Time Before: 0.02780 seconds
Time After: 0.03510 seconds
Time Taken: 0.00731 seconds
Time Before: 0.04165 seconds
Time After: 0.04209 seconds
Time Before: 0.04472 seconds
Time After: 0.04595 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04095 seconds
Time After: 0.04620 seconds
Time Taken: 0.00525 seconds
Memory After: 2,261.836 KB
Time Before: 0.07425 seconds
Time After: 0.07438 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.08968 seconds
Time After: 0.09117 seconds
Time Taken: 0.00150 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.10117 seconds
Time After: 0.10134 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.10380 seconds
Time After: 0.10616 seconds
Time Taken: 0.00237 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1788935779, location = '/forums/private.php?do=newpm&explain=1&u=5605', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.12264 seconds
Time After: 0.12296 seconds
Memory Before: 4,287.867 KB
Memory After: 4,288.078 KB
