Time Before: 0.01690 seconds
Time After: 0.02493 seconds
Time Taken: 0.00804 seconds
Time Before: 0.02501 seconds
Time After: 0.02535 seconds
Time Before: 0.02554 seconds
Time After: 0.02567 seconds
Time Before: 0.02654 seconds
Time After: 0.02936 seconds
Time Taken: 0.00282 seconds
Time Before: 0.02573 seconds
Time After: 0.03390 seconds
Time Taken: 0.00817 seconds
Time Before: 0.04121 seconds
Time After: 0.04159 seconds
Time Before: 0.04394 seconds
Time After: 0.04525 seconds
Time Taken: 0.00131 seconds
Time Before: 0.04056 seconds
Time After: 0.04550 seconds
Time Taken: 0.00495 seconds
Time Before: 0.07680 seconds
Time After: 0.07693 seconds
Time Before: 0.09500 seconds
Time After: 0.09724 seconds
Time Taken: 0.00223 seconds
End call of global.php: 0.099711894989014
Time Before: 0.10788 seconds
Time After: 0.10803 seconds
Time Before: 0.11072 seconds
Time After: 0.11222 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=56131', badlocation = 1
Time Before: 0.12938 seconds
Time After: 0.12968 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.12822103500366 seconds with 9 queries, spending 0.0092856884002686 doing MySQL queries and 0.11893534660339 doing PHP things.
