Time Before: 0.02126 seconds
Time After: 0.02889 seconds
Time Taken: 0.00763 seconds
Time Before: 0.02898 seconds
Time After: 0.02947 seconds
Time Before: 0.02973 seconds
Time After: 0.02987 seconds
Time Before: 0.03064 seconds
Time After: 0.03323 seconds
Time Taken: 0.00259 seconds
Time Before: 0.02992 seconds
Time After: 0.03803 seconds
Time Taken: 0.00811 seconds
Time Before: 0.04516 seconds
Time After: 0.04553 seconds
Time Before: 0.04688 seconds
Time After: 0.04810 seconds
Time Before: 0.04444 seconds
Time After: 0.04829 seconds
Time Taken: 0.00385 seconds
Time Before: 0.07732 seconds
Time After: 0.07747 seconds
Time Before: 0.09571 seconds
Time After: 0.09695 seconds
End call of global.php: 0.099228143692017
Time Before: 0.11382 seconds
Time After: 0.11404 seconds
Time Before: 0.11652 seconds
Time After: 0.11809 seconds
Time Taken: 0.00156 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=56162'
Time Before: 0.13683 seconds
Time After: 0.13719 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.13548016548157 seconds with 9 queries, spending 0.0083549022674561 doing MySQL queries and 0.12712526321411 doing PHP things.
