Time Before: 0.00201 seconds
Time After: 0.00255 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00263 seconds
Time After: 0.00299 seconds
Time Before: 0.00324 seconds
Time After: 0.00339 seconds
Time Before: 0.00420 seconds
Time After: 0.00680 seconds
Time Taken: 0.00260 seconds
Time Before: 0.00343 seconds
Time After: 0.01030 seconds
Time Taken: 0.00687 seconds
Time Before: 0.01234 seconds
Time After: 0.01275 seconds
Time Before: 0.01608 seconds
Time After: 0.01729 seconds
Time Before: 0.01167 seconds
Time After: 0.01745 seconds
Time Taken: 0.00579 seconds
Time Before: 0.02258 seconds
Time After: 0.02278 seconds
Time Before: 0.02463 seconds
Time After: 0.02590 seconds
End call of global.php: 0.027529954910278
Time Before: 0.02891 seconds
Time After: 0.02905 seconds
Time Before: 0.03112 seconds
Time After: 0.03259 seconds
SET lastactivity = 1776545878, location = '/forums/private.php?do=newpm&explain=1&u=56168'
Time Before: 0.04627 seconds
Time After: 0.04659 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.045360088348389 seconds with 9 queries, spending 0.00813889503479 doing MySQL queries and 0.037221193313599 doing PHP things.
