Time Before: 0.00196 seconds
Time After: 0.00266 seconds
Time Taken: 0.00071 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.00276 seconds
Time After: 0.00323 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.00349 seconds
Time After: 0.00363 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.00449 seconds
Time After: 0.00710 seconds
Time Taken: 0.00261 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.00370 seconds
Time After: 0.01093 seconds
Time Taken: 0.00723 seconds
Memory Before: 560.883 KB
Memory After: 1,641.914 KB
Time Before: 0.01291 seconds
Time After: 0.01315 seconds
Time Before: 0.01575 seconds
Time After: 0.01698 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01235 seconds
Time After: 0.01723 seconds
Time Taken: 0.00488 seconds
Memory After: 2,261.703 KB
Time Before: 0.02414 seconds
Time After: 0.02429 seconds
Memory Before: 2,815.273 KB
Memory After: 2,815.789 KB
Time Before: 0.02658 seconds
Time After: 0.02781 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.03190 seconds
Time After: 0.03216 seconds
Memory Before: 3,540.375 KB
Memory After: 3,540.805 KB
Time Before: 0.03540 seconds
Time After: 0.03694 seconds
Time Taken: 0.00154 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=56176' WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.05002 seconds
Time After: 0.05028 seconds
Memory Before: 4,295.484 KB
Memory After: 4,295.727 KB
