Time Before: 0.00240 seconds
Time After: 0.00343 seconds
Time Taken: 0.00103 seconds
Time Before: 0.00354 seconds
Time After: 0.00404 seconds
Time Before: 0.00426 seconds
Time After: 0.00439 seconds
Time Before: 0.00518 seconds
Time After: 0.00895 seconds
Time Taken: 0.00377 seconds
Time Before: 0.00444 seconds
Time After: 0.01357 seconds
Time Taken: 0.00913 seconds
Time Before: 0.01610 seconds
Time After: 0.01655 seconds
Time Before: 0.01905 seconds
Time After: 0.02072 seconds
Time Taken: 0.00168 seconds
Time Before: 0.01538 seconds
Time After: 0.02090 seconds
Time Taken: 0.00552 seconds
Time Before: 0.02659 seconds
Time After: 0.02686 seconds
Time Before: 0.02896 seconds
Time After: 0.03021 seconds
End call of global.php: 0.032961130142212
Time Before: 0.03438 seconds
Time After: 0.03459 seconds
Time Before: 0.03701 seconds
Time After: 0.03855 seconds
Time Taken: 0.00154 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=56367'
Time Before: 0.05163 seconds
Time After: 0.05190 seconds
Memory Before: 4,288.555 KB
Memory After: 4,288.797 KB
Page generated in 0.050727128982544 seconds with 9 queries, spending 0.010064601898193 doing MySQL queries and 0.040662527084351 doing PHP things.
