Time Before: 0.00136 seconds
Time After: 0.00181 seconds
Time Before: 0.00188 seconds
Time After: 0.00231 seconds
Time Before: 0.00256 seconds
Time After: 0.00273 seconds
Time Before: 0.00361 seconds
Time After: 0.00642 seconds
Time Taken: 0.00281 seconds
Time Before: 0.00280 seconds
Time After: 0.00983 seconds
Time Taken: 0.00703 seconds
Time Before: 0.01164 seconds
Time After: 0.01209 seconds
Time Before: 0.01465 seconds
Time After: 0.01587 seconds
Time Before: 0.01102 seconds
Time After: 0.01616 seconds
Time Taken: 0.00513 seconds
Time Before: 0.02227 seconds
Time After: 0.02240 seconds
Time Before: 0.02477 seconds
Time After: 0.02605 seconds
End call of global.php: 0.02863597869873
Time Before: 0.03016 seconds
Time After: 0.03039 seconds
Time Before: 0.03308 seconds
Time After: 0.03451 seconds
SET lastactivity = 1788959789, location = '/forums/private.php?do=newpm&explain=1&u=56426'
Time Before: 0.04974 seconds
Time After: 0.04997 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.048843860626221 seconds with 9 queries, spending 0.0083842277526855 doing MySQL queries and 0.040459632873535 doing PHP things.
