Time Before: 0.00145 seconds
Time After: 0.00189 seconds
Time Before: 0.00196 seconds
Time After: 0.00240 seconds
Time Before: 0.00263 seconds
Time After: 0.00275 seconds
Time Before: 0.00347 seconds
Time After: 0.00629 seconds
Time Taken: 0.00283 seconds
Time Before: 0.00280 seconds
Time After: 0.00980 seconds
Time Taken: 0.00699 seconds
Time Before: 0.01175 seconds
Time After: 0.01211 seconds
Time Before: 0.01472 seconds
Time After: 0.01596 seconds
Time Before: 0.01116 seconds
Time After: 0.01615 seconds
Time Taken: 0.00499 seconds
Time Before: 0.02396 seconds
Time After: 0.02413 seconds
Time Before: 0.02623 seconds
Time After: 0.02747 seconds
Time Before: 0.03060 seconds
Time After: 0.03077 seconds
Time Before: 0.03340 seconds
Time After: 0.03499 seconds
Time Taken: 0.00158 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=5644', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04929 seconds
Time After: 0.04960 seconds
Memory Before: 4,911.086 KB
Memory After: 4,911.313 KB
