Time Before: 0.00157 seconds
Time After: 0.00211 seconds
Time Taken: 0.00054 seconds
Memory Before: 1,157.773 KB
Memory After: 1,182.891 KB
Time Before: 0.00220 seconds
Time After: 0.00278 seconds
Time Taken: 0.00058 seconds
Memory Before: 1,182.828 KB
Memory After: 1,183.836 KB
Time Before: 0.00306 seconds
Time After: 0.00324 seconds
Memory Before: 1,184.422 KB
Memory After: 1,184.945 KB
Time Before: 0.00401 seconds
Time After: 0.00593 seconds
Time Taken: 0.00192 seconds
Memory Before: 1,187.547 KB
Memory After: 1,188.469 KB
Time Before: 0.00329 seconds
Time After: 0.00936 seconds
Time Taken: 0.00607 seconds
Memory Before: 1,184.164 KB
Memory After: 2,265.219 KB
Memory Used: 1,081.055 KB
Time Before: 0.01179 seconds
Time After: 0.01227 seconds
Memory Before: 2,758.023 KB
Memory After: 2,758.641 KB
Time Before: 0.01514 seconds
Time After: 0.01635 seconds
Memory Before: 2,770.195 KB
Memory After: 2,770.055 KB
Time Before: 0.01081 seconds
Time After: 0.01664 seconds
Time Taken: 0.00583 seconds
Memory Before: 2,750.172 KB
Memory After: 2,883.414 KB
Memory Used: 133.242 KB
Time Before: 0.02424 seconds
Time After: 0.02442 seconds
Memory Before: 3,436.539 KB
Memory After: 3,437.055 KB
Time Before: 0.02692 seconds
Time After: 0.02820 seconds
Memory Before: 3,524.336 KB
Memory After: 3,524.930 KB
End call of global.php: 0.029912948608398
Time Before: 0.03168 seconds
Time After: 0.03186 seconds
Memory Before: 4,162.242 KB
Memory After: 4,162.672 KB
Time Before: 0.03502 seconds
Time After: 0.03648 seconds
Memory Before: 4,443.805 KB
Memory After: 4,445.492 KB
SET lastactivity = 1789066771, location = '/forums/private.php?do=newpm&explain=1&u=56490', badlocation = 1
Time Before: 0.05172 seconds
Time After: 0.05200 seconds
Memory Before: 4,922.375 KB
Memory After: 4,922.586 KB
Page generated in 0.050806045532227 seconds with 9 queries, spending 0.0077469348907471 doing MySQL queries and 0.043059110641479 doing PHP things.
