Time Before: 0.01020 seconds
Time After: 0.01457 seconds
Time Taken: 0.00437 seconds
Time Before: 0.01471 seconds
Time After: 0.01509 seconds
Time Before: 0.01535 seconds
Time After: 0.01552 seconds
Time Before: 0.01638 seconds
Time After: 0.01895 seconds
Time Taken: 0.00257 seconds
Time Before: 0.01562 seconds
Time After: 0.02307 seconds
Time Taken: 0.00745 seconds
Time Before: 0.03156 seconds
Time After: 0.03192 seconds
Time Before: 0.03461 seconds
Time After: 0.03589 seconds
Time Before: 0.03081 seconds
Time After: 0.03609 seconds
Time Taken: 0.00528 seconds
Time Before: 0.06370 seconds
Time After: 0.06384 seconds
Time Before: 0.07488 seconds
Time After: 0.07617 seconds
Time Before: 0.08570 seconds
Time After: 0.08586 seconds
Time Before: 0.08927 seconds
Time After: 0.09075 seconds
UPDATE session SET lastactivity = 1783115636, location = '/forums/private.php?do=newpm&explain=1&u=56514' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.11176 seconds
Time After: 0.11209 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
