Time Before: 0.02784 seconds
Time After: 0.03577 seconds
Time Taken: 0.00793 seconds
Time Before: 0.03586 seconds
Time After: 0.03633 seconds
Time Before: 0.03664 seconds
Time After: 0.03680 seconds
Time Before: 0.03768 seconds
Time After: 0.04046 seconds
Time Taken: 0.00278 seconds
Time Before: 0.03688 seconds
Time After: 0.04555 seconds
Time Taken: 0.00867 seconds
Time Before: 0.05809 seconds
Time After: 0.05831 seconds
Time Before: 0.06081 seconds
Time After: 0.06208 seconds
Time Before: 0.05738 seconds
Time After: 0.06234 seconds
Time Taken: 0.00496 seconds
Time Before: 0.10306 seconds
Time After: 0.10322 seconds
Time Before: 0.13981 seconds
Time After: 0.14107 seconds
Time Before: 0.15421 seconds
Time After: 0.15437 seconds
Time Before: 0.15682 seconds
Time After: 0.15839 seconds
Time Taken: 0.00156 seconds
UPDATE session SET lastactivity = 1785412636, location = '/forums/private.php?do=newpm&explain=1&u=56533', badlocation = 1 WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.18041 seconds
Time After: 0.18070 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
