Time Before: 0.02398 seconds
Time After: 0.03031 seconds
Time Taken: 0.00633 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.03041 seconds
Time After: 0.03091 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.03113 seconds
Time After: 0.03126 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.03208 seconds
Time After: 0.03437 seconds
Time Taken: 0.00229 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.03132 seconds
Time After: 0.03887 seconds
Time Taken: 0.00754 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.04569 seconds
Time After: 0.04609 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04855 seconds
Time After: 0.04974 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.04487 seconds
Time After: 0.04999 seconds
Time Taken: 0.00512 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.09210 seconds
Time After: 0.09223 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.15931 seconds
Time After: 0.16055 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.16255879402161
Time Before: 0.19180 seconds
Time After: 0.19195 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.19962 seconds
Time After: 0.20146 seconds
Time Taken: 0.00185 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=56539', badlocation = 1
Time Before: 0.23626 seconds
Time After: 0.23655 seconds
Memory Before: 5,997.742 KB
Memory After: 5,997.961 KB
Page generated in 0.23457193374634 seconds with 9 queries, spending 0.008181095123291 doing MySQL queries and 0.22639083862305 doing PHP things.
