Time Before: 0.00208 seconds
Time After: 0.00281 seconds
Time Taken: 0.00073 seconds
Time Before: 0.00291 seconds
Time After: 0.00345 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00371 seconds
Time After: 0.00387 seconds
Time Before: 0.00480 seconds
Time After: 0.00763 seconds
Time Taken: 0.00282 seconds
Time Before: 0.00395 seconds
Time After: 0.01290 seconds
Time Taken: 0.00895 seconds
Time Before: 0.01535 seconds
Time After: 0.01554 seconds
Time Before: 0.01693 seconds
Time After: 0.01872 seconds
Time Taken: 0.00180 seconds
Time Before: 0.01457 seconds
Time After: 0.01891 seconds
Time Taken: 0.00434 seconds
Time Before: 0.02518 seconds
Time After: 0.02534 seconds
Time Before: 0.02753 seconds
Time After: 0.02876 seconds
Time Before: 0.03242 seconds
Time After: 0.03256 seconds
Time Before: 0.03458 seconds
Time After: 0.03611 seconds
Time Taken: 0.00153 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=56571', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.05026 seconds
Time After: 0.05052 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
