Time Before: 0.02125 seconds
Time After: 0.02820 seconds
Time Taken: 0.00695 seconds
Time Before: 0.02830 seconds
Time After: 0.02874 seconds
Time Before: 0.02895 seconds
Time After: 0.02907 seconds
Time Before: 0.02988 seconds
Time After: 0.03253 seconds
Time Taken: 0.00265 seconds
Time Before: 0.02914 seconds
Time After: 0.03717 seconds
Time Taken: 0.00803 seconds
Time Before: 0.04490 seconds
Time After: 0.04534 seconds
Time Before: 0.04805 seconds
Time After: 0.04929 seconds
Time Before: 0.04410 seconds
Time After: 0.04954 seconds
Time Taken: 0.00543 seconds
Time Before: 0.09018 seconds
Time After: 0.09031 seconds
Time Before: 0.10746 seconds
Time After: 0.10874 seconds
Time Before: 0.11807 seconds
Time After: 0.11823 seconds
Time Before: 0.12096 seconds
Time After: 0.12249 seconds
Time Taken: 0.00153 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=56697', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.14251 seconds
Time After: 0.14280 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
