Time Before: 0.01455 seconds
Time After: 0.02445 seconds
Time Taken: 0.00990 seconds
Memory Before: 533.906 KB
Memory After: 559.023 KB
Time Before: 0.02455 seconds
Time After: 0.02506 seconds
Memory Before: 558.961 KB
Memory After: 559.969 KB
Time Before: 0.02536 seconds
Time After: 0.02551 seconds
Memory Before: 560.523 KB
Memory After: 561.047 KB
Time Before: 0.02637 seconds
Time After: 0.02871 seconds
Time Taken: 0.00234 seconds
Memory Before: 563.648 KB
Memory After: 564.570 KB
Time Before: 0.02557 seconds
Time After: 0.03273 seconds
Time Taken: 0.00716 seconds
Memory Before: 560.297 KB
Memory After: 1,641.297 KB
Memory Used: 1,081.000 KB
Time Before: 0.04210 seconds
Time After: 0.04249 seconds
Memory Before: 2,136.141 KB
Memory After: 2,136.758 KB
Time Before: 0.04525 seconds
Time After: 0.04692 seconds
Time Taken: 0.00167 seconds
Memory Before: 2,148.320 KB
Memory After: 2,148.180 KB
Time Before: 0.04138 seconds
Time After: 0.04717 seconds
Time Taken: 0.00579 seconds
Memory Before: 2,128.320 KB
Memory After: 2,261.203 KB
Time Before: 0.06507 seconds
Time After: 0.06536 seconds
Memory Before: 2,814.781 KB
Memory After: 2,815.297 KB
REPLACE INTO datastore
	(title, data, unserialize)
VALUES
	('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"40.04,\";s:9:\"lastcheck\";i:1788899572;}', 1)
Time Before: 0.08188 seconds
Time After: 0.08233 seconds
Memory Before: 2,816.047 KB
Memory After: 2,816.297 KB
Memory Used: 0.250 KB
Time Before: 0.10555 seconds
Time After: 0.10691 seconds
Time Taken: 0.00136 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.11020612716675
Time Before: 0.12026 seconds
Time After: 0.12046 seconds
Memory Before: 3,540.258 KB
Memory After: 3,540.688 KB
Time Before: 0.12310 seconds
Time After: 0.12482 seconds
Time Taken: 0.00172 seconds
Memory Before: 3,821.836 KB
Memory After: 3,823.523 KB
SET lastactivity = 1788899572, location = '/forums/private.php?do=newpm&explain=1&u=56771'
Time Before: 0.14473 seconds
Time After: 0.14614 seconds
Memory Before: 4,295.688 KB
Memory After: 4,295.914 KB
Page generated in 0.14331007003784 seconds with 10 queries, spending 0.010471343994141 doing MySQL queries and 0.1328387260437 doing PHP things.
