Time Before: 0.00519 seconds
Time After: 0.00691 seconds
Time Taken: 0.00172 seconds
Time Before: 0.00698 seconds
Time After: 0.00741 seconds
Time Before: 0.00769 seconds
Time After: 0.00784 seconds
Time Before: 0.00866 seconds
Time After: 0.01160 seconds
Time Taken: 0.00294 seconds
Time Before: 0.00790 seconds
Time After: 0.01629 seconds
Time Taken: 0.00839 seconds
Time Before: 0.02024 seconds
Time After: 0.02067 seconds
Time Before: 0.02322 seconds
Time After: 0.02447 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01953 seconds
Time After: 0.02470 seconds
Time Taken: 0.00517 seconds
Memory After: 2,261.719 KB
Time Before: 0.03492 seconds
Time After: 0.03507 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.04114 seconds
Time After: 0.04239 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.04792 seconds
Time After: 0.04810 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.05060 seconds
Time After: 0.05250 seconds
Time Taken: 0.00190 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=56795' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.06535 seconds
Time After: 0.06574 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
