Time Before: 0.00155 seconds
Time After: 0.00203 seconds
Time Before: 0.00210 seconds
Time After: 0.00263 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00286 seconds
Time After: 0.00301 seconds
Time Before: 0.00379 seconds
Time After: 0.00667 seconds
Time Taken: 0.00287 seconds
Time Before: 0.00305 seconds
Time After: 0.01146 seconds
Time Taken: 0.00841 seconds
Time Before: 0.01369 seconds
Time After: 0.01408 seconds
Time Before: 0.01657 seconds
Time After: 0.01788 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01311 seconds
Time After: 0.01813 seconds
Time Taken: 0.00501 seconds
Time Before: 0.02380 seconds
Time After: 0.02398 seconds
Time Before: 0.02618 seconds
Time After: 0.02744 seconds
End call of global.php: 0.029365062713623
Time Before: 0.03083 seconds
Time After: 0.03102 seconds
Time Before: 0.03404 seconds
Time After: 0.03554 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=56812'
WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.05043 seconds
Time After: 0.05081 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.049484014511108 seconds with 9 queries, spending 0.0087654590606689 doing MySQL queries and 0.040718555450439 doing PHP things.
