Time Before: 0.02039 seconds
Time After: 0.02396 seconds
Time Taken: 0.00357 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.02410 seconds
Time After: 0.02450 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.02473 seconds
Time After: 0.02488 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.02566 seconds
Time After: 0.02817 seconds
Time Taken: 0.00251 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.02495 seconds
Time After: 0.03272 seconds
Time Taken: 0.00777 seconds
Memory Before: 560.883 KB
Memory After: 1,641.914 KB
Time Before: 0.03839 seconds
Time After: 0.03890 seconds
Time Before: 0.04147 seconds
Time After: 0.04278 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03778 seconds
Time After: 0.04302 seconds
Time Taken: 0.00524 seconds
Memory After: 2,261.703 KB
Time Before: 0.07009 seconds
Time After: 0.07029 seconds
Memory Before: 2,815.273 KB
Memory After: 2,815.789 KB
Time Before: 0.08442 seconds
Time After: 0.08572 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.088594913482666
Time Before: 0.09407 seconds
Time After: 0.09429 seconds
Memory Before: 3,540.375 KB
Memory After: 3,540.805 KB
Time Before: 0.09752 seconds
Time After: 0.09900 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=56914', badlocation = 1
Time Before: 0.11780 seconds
Time After: 0.11810 seconds
Memory Before: 4,295.766 KB
Memory After: 4,295.992 KB
Page generated in 0.11662888526917 seconds with 9 queries, spending 0.0083770751953125 doing MySQL queries and 0.10825181007385 doing PHP things.
