Time Before: 0.02097 seconds
Time After: 0.02911 seconds
Time Taken: 0.00814 seconds
Time Before: 0.02918 seconds
Time After: 0.02963 seconds
Time Before: 0.02991 seconds
Time After: 0.03007 seconds
Time Before: 0.03096 seconds
Time After: 0.03296 seconds
Time Taken: 0.00200 seconds
Time Before: 0.03015 seconds
Time After: 0.03829 seconds
Time Before: 0.04632 seconds
Time After: 0.04673 seconds
Time Before: 0.04983 seconds
Time After: 0.05152 seconds
Time Taken: 0.00169 seconds
Time Before: 0.04556 seconds
Time After: 0.05176 seconds
Time Taken: 0.00621 seconds
Time Before: 0.08899 seconds
Time After: 0.08921 seconds
Time Before: 0.10835 seconds
Time After: 0.10962 seconds
Time Before: 0.12015 seconds
Time After: 0.12034 seconds
Time Before: 0.12312 seconds
Time After: 0.12458 seconds
UPDATE session SET lastactivity = 1789066163, location = '/forums/private.php?do=newpm&explain=1&u=56946', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.14508 seconds
Time After: 0.14537 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
