Time Before: 0.00419 seconds
Time After: 0.00523 seconds
Time Taken: 0.00105 seconds
Time Before: 0.00533 seconds
Time After: 0.00580 seconds
Time Before: 0.00601 seconds
Time After: 0.00613 seconds
Time Before: 0.00681 seconds
Time After: 0.00986 seconds
Time Taken: 0.00305 seconds
Time Before: 0.00618 seconds
Time After: 0.01322 seconds
Time Taken: 0.00704 seconds
Time Before: 0.01607 seconds
Time After: 0.01647 seconds
Time Before: 0.01793 seconds
Time After: 0.01912 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01534 seconds
Time After: 0.01936 seconds
Time Taken: 0.00402 seconds
Time Before: 0.02553 seconds
Time After: 0.02565 seconds
Time Before: 4.77422 seconds
Time After: 4.77622 seconds
Time Taken: 0.00200 seconds
End call of global.php: 4.778990983963
Time Before: 4.78169 seconds
Time After: 4.78192 seconds
Time Before: 4.78413 seconds
Time After: 4.78568 seconds
Time Taken: 0.00154 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=57046'
Time Before: 4.80821 seconds
Time After: 4.80844 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 4.8068008422852 seconds with 9 queries, spending 0.0093529224395752 doing MySQL queries and 4.7974479198456 doing PHP things.
