Time Before: 0.00153 seconds
Time After: 0.00211 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00218 seconds
Time After: 0.00276 seconds
Time Before: 0.00309 seconds
Time After: 0.00327 seconds
Time Before: 0.00402 seconds
Time After: 0.00662 seconds
Time Taken: 0.00260 seconds
Time Before: 0.00333 seconds
Time After: 0.01174 seconds
Time Taken: 0.00840 seconds
Time Before: 0.01410 seconds
Time After: 0.01436 seconds
Time Before: 0.01594 seconds
Time After: 0.01718 seconds
Time Before: 0.01337 seconds
Time After: 0.01743 seconds
Time Taken: 0.00405 seconds
Time Before: 0.02309 seconds
Time After: 0.02320 seconds
Time Before: 0.02796 seconds
Time After: 0.02923 seconds
Time Before: 0.03344 seconds
Time After: 0.03362 seconds
Time Before: 0.03578 seconds
Time After: 0.03722 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=57120', badlocation = 1 WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.04966 seconds
Time After: 0.04999 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
